Build error for library: C:\Users\TamNguyen\AppData\Roaming\Dynamo\Dynamo Revit\3.6\packages\BriMohareb_2026\bin\BriMohareb_2026.dll
System.IO.FileLoadException: Could not load file or assembly ‘Autodesk.AutoCAD.Interop, Version=25.1.0.0, Culture=neutral, PublicKeyToken=null’. Could not find or load a specific file. (0x80131621)
File name: ‘Autodesk.AutoCAD.Interop, Version=25.1.0.0, Culture=neutral, PublicKeyToken=null’
—> System.IO.FileLoadException: Could not load file or assembly ‘Autodesk.AutoCAD.Interop, Version=25.1.0.0, Culture=neutral, PublicKeyToken=null’.
at System.Runtime.Loader.AssemblyLoadContext.g____PInvoke|5_0(IntPtr __ptrNativeAssemblyBinder_native, UInt16* __ilPath_native, UInt16* __niPath_native, ObjectHandleOnStack __retAssembly_native)
at System.Runtime.Loader.AssemblyLoadContext.LoadFromAssemblyPath(String assemblyPath)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at System.Reflection.Assembly.LoadFromResolveHandler(Object sender, ResolveEventArgs args)
at System.Runtime.Loader.AssemblyLoadContext.InvokeResolveEvent(ResolveEventHandler eventHandler, RuntimeAssembly assembly, String name)
at System.Signature.GetSignature(Void* pCorSig, Int32 cCorSig, RuntimeFieldHandleInternal fieldHandle, IRuntimeMethodInfo methodHandle, RuntimeType declaringType)
at System.Reflection.RtFieldInfo.InitializeFieldType()
at System.Reflection.RuntimeFieldInfo.ToString()
at System.Runtime.CompilerServices.DefaultInterpolatedStringHandler.AppendFormatted[T](T value)
at ProtoFFI.CLRModuleType.ParseSystemType(Type type, String alias)
at ProtoFFI.CLRModuleType.GetInstance(Type type, CLRDLLModule module, String alias)
at ProtoFFI.CLRDLLModule.ImportCodeBlock(String typeName, String alias, CodeBlockNode refNode)
at ProtoFFI.ImportModuleHandler.ImportCodeBlock(String importModuleName, String typeName, String alias, CodeBlockNode refNode)
at ProtoFFI.ImportModuleHandler.Import(String moduleName, String typeName, String alias, Int32 line, Int32 col)
Dynamo.Exceptions.LibraryLoadFailedException:
Failed to load library: C:\Users\TamNguyen\AppData\Roaming\Dynamo\Dynamo Revit\3.6\packages\BriMohareb_2026\bin\BriMohareb_2026
