@andy.leong @jacob.small @Vikram_Subbaiah
Can you please help?
I am trying to generate a twisting tower in dynamo but the slab edge is a bit complicated, I have selected the slab edge from a family file, then generated the dynamo geometry.
The problem is I want to further develop the Dynamo script to generate a mass tower, floors, and facade skin in a Revit project file, but since the Dynamo file is associated with only one Revit file, I have already used that to select the slab edge.
Is there any way to generate the attached slab edge in Dynamo directly without needing to select it from a family, or can I associate a dynamo file to two revit files, one to select the slab to generate the tower, and the other to create a tower mass, facade, and floors in Revit.
Revit V2020.2
Dynamo V2.3.0
Attached slab edge picture & family, and the dynamo script.
Backup 01.dyn (52.3 KB) Tower Slab Edge.rfa (336 KB)thanks,
