I have started getting the following error now in Revit 2020, 2021, 2022 but not 2023. Not sure when it started or whats causing it. Any suggestions would be great
System.TypeLoadExceptions: Method ‘SignRequest’ in type
‘Greg.AuthProviders.RevitOxygenProvider’ from assembly
‘GregRevitAuth, Version=1.0.7057.20655, Culture=neutral,
PublicKeyToken=null’ does not have an implementation.
at
Dynamo.Applications.DynamoRevit.InitializeCoreModel (DynamoRevitCommandData
commandData)
at
Dynamo.Applications.DynamoRevit.ExecuteCommand (DynamoRevitCommandData
commandData)
I’m getting the exact same message in Revit 2022 when I try to launch Dynamo. Were you able to reach a resolution with Autodesk support?
EDIT: Actually, I just uninstalled the CTC BIM Manager add-on and then I was able to open Dynamo again. I only had a trial version of the CTC add-on and the trial license had expired. Not sure if that’s relevant, just another tidbit of information.
thanks for sharing.
have uninstalled CTC nevest version and now I am able to run Dynamo again.
reported bug to CTC as well. they offer some nice free tools I like to use, but when its not possible to use Dynamo same time, thats not so nice
