Hi all,
I have noticed that if the install executable is run in the System context (Ex: script executed via Software Center or SCCM), Dynamo Core does not install, regardless of the Dynamo version. Running the exact same command line in the user context by having the user execute the script in Windows by double-clicking or pasting a path with switches to the CMD Window with admin rights, then Dynamo Core does install. It also doesn’t matter whether I use the following switches or any combination thereof, or none: Core still does not install (/SILENT /NORESTART /NOCLOSEAPPLICATIONS). I’m testing under Windows 10. Any ideas or is this a known issue? Thanks.
