Dynamo as a Service & Forma - Run Failed
Is anyone else experiencing issues with Dynamo as a Service through Forma Site Design? This is specifically - for me - through Desktop mode. Just yesterday I was working on the dynamo file just fine. But now when I try to run it, I just get a “Run Failed” error. Odd thing is, if I click run on the workflow in Dynamo, it will run and create the geometry (in Dynamo).
I have noticed this a few times and it seems to occur when I switch between Forma Site Design projects. For example, just this morning I tried running the workflow on a new site. I received the “run failed” error then ran the workflow in Dynamo. Even though I was in a new Forma Site Design project, the Forma Dynamo nodes were still pulling the site, terrain, and boundary curves from the old Forma Site Design project.
Even after starting a new dynamo file and only adding Forma nodes to retrieve site and terrain info, it still failed.
It’s worth noting we do use Orkestra to deploy Dynamo, manage packages and workflows. Opening Dynamo straight through Revit still throws the same error. I have tried clearing cache, restarting my computer, logging out of Forma, everything I can think of.
