Hi guys,
I´m a new dynamo-user, tried some little things an need your help please.
I want to check and later edit some parameter of ducts. At first I want to check only the high and width.
In german “Höhe” and “Breite”.
With the parameter Breite everything works well, but I can’t check the parameter “Höhe” - because of the umlaut.
Is there any possibility to make this run?
I tried the UTF-8 code, the ö without any result.
Another, little question:
Is there a way to change from imperial to the metric units?
I changed the option “Lenght display units” to Millimeter, without any result?
For example 200mm is 0.656ft - 0,656ft / 304, … shows me the correct 200mm
