Duplicate / Copy Layouts
is there any node that duplicates an existing layout n times ?
if not, could you please help me write a python code that does exactly this ?
Many thanks.
Hi , here an example with Python
code (use PythonNet3)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
db = adoc.Database
class CManager:
    a custom context manager for Disposable Object
    def __init__(self, obj):
        self.obj = obj
    def __enter__(self):
        return self.obj
    def __exit__(self, exc_type, exc_value, exc_tb):
        self.obj.Dispose()
        if exc_type:
            error = f"{exc_value} at line {exc_tb.tb_lineno}"
            raise ValueError( error)
        return self
layout_name = IN[0]
with adoc.LockDocument():
    with CManager(adoc.Database) as db:
        with CManager(db.TransactionManager.StartTransaction()) as t:
            layout_dict = t.GetObject(db.LayoutDictionaryId, OpenMode.ForRead)
            if layout_dict.Contains(layout_name):
                target_name = layout_name + "-Copy"
                # copy the layout via the global LayoutManager
                lm = LayoutManager.Current
                lm.CloneLayout(layout_name, target_name, lm.LayoutCount + 1)
                # OR
                # lm.CopyLayout(layout_name, target_name)
            t.Commit()
Many thanks Cyril,
This creates a single copy from a given layout, is there a way to enhance this by adding the number of duplications desired as an input ?
sure
import sys
db = adoc.Database
class CManager:
        self.obj = obj
        return self.obj
        self.obj.Dispose()
        if exc_type:
        return self
layout_name_to_duplicate = IN[0]
new_names = IN[1]
            if layout_dict.Contains(layout_name_to_duplicate):
                for target_name in new_names:
                    lm.CloneLayout(layout_name_to_duplicate, target_name, lm.LayoutCount + 1)
                    # OR
                    # lm.CopyLayout(layout_name_to_duplicate, target_name)
            t.Commit()
Astonishing ! This does exactly that.
Thank you so much for your time and effort Cyril. :slightly_smiling_face:
