Dear Friends,
how can we make double sorting. I mean firstly sort by Valve type then by size of valve. I prepared photo what i mentioned.
Or if the prefix to the values are always going to be the same, you could remove the prefix of the strings and use the SortByFunction node.
Using a List.GroupByKey node and feeding that into a List.SortByKey with lacing set to longest should also work without requiring python.
