Hi Masters,
I modified a script for door catalog that is used the the project. But the door is not following the level and host that I specified in the dynamo script. Please help thanks.
regards,
Greg Palermo
I just solve it. Thanks Guys
Hi Masters,
regards,
Greg Palermo
Hi @gregorio.palermo,
first of all there are no Masters here, this is not a porn-website
Can you show us the error on the Point.ByCoords node?
Hi @Ernesto_Pellegrino ,
I have another question also;
1.If I run the dynamo the walls on the 1st coordinate wall move to the next coordinate that I specify.
2. I have to close and open dynamo just to create 2nd lane of walls.But up to 2 lane only no more thant 3 lanes.
3. I have to run dynamo twice to push the doors in the walls.
- 1st run doors will be deleted and continue to next run
- 2nd run success on hosting.
here is the error:
all I can say on this image is that you should change your Dynamo working range
If you could post the script and the revit file I could take a look at it more closely.
