hi, I am trying to get my Grasshopper scripts work in Dynamo. can I ask what is Grasshopper “Divide Domain 2” & “Isotrim” & “cross reference” in Dynamo?
Yes! And what should I type in the CODE BLOCK?
0…1…#14 means a range from 0 to 1 divided in 14 steps, it’s called desgnscript.
DesignScriptDocumentation.pdf (705.5 KB)
designscript-final.pdf (1.5 MB)
DesignScriptGuide.pdf (3.7 MB)
@Marcel_Rijsmus
yes! that’s exactly what i am looking for. basically i did the crossing lines in between 2 surfaces on grasshopper, and i m trying to achieve the same outcome in dynamo. however, i am stacked with the Deconstrust Brep/Topology. Vertice. do you have any idea about how does it works in dynamo?
your filter by boolean mask needs some booleans is all i can tell you
some guys know all nodes
i’ve joined this community in 2014, still learning
