Translated by moderator. See below the line for original post.
Hello good afternoon, can someone help me to create this varied division, with a geometry or family, thank you very much!
Original post below.
Hola buenas tardes, alguien me puede ayudar en poder crear esta división variada, con una geometría o familia muchas gracias!
Hello @eduarrom and welcome to the forum. The officially language here is English, so please translate all posts as I have done above. This is a requirement to make search work.
To do this via Dynamo I recommend looking into FamilyInstance.ByPoint, and setting rotation accordingly. You’ll have to build the family first though. Alternatively you could use a curtain wall family where the mullions are the vertical elements you’re after, and place a curtain grid at the desired points. Give it a shot and see where you get.
Thank you very much for your reply. But I am very new to dynamo.
I have families. I still don’t understand how to apply what you said to my project.
Thank you
I recommend to run through the Dynamo Primer as a first start then: About | The Dynamo Primer
Skip nothing even if it doesn’t feel relevant to what you want to do - the means are what you are after learning not the ends.
