… can i see that as “get” and “Set” values? or means “map” like copy something …
KR
Andreas
Hopefully somebody else will elaborate or correct me if I’m wrong.
I believe Parameters returns a list of the actual parameter objects which can make looping or searching slower with larger data sets. ParametersMap returns a “map” of the element’s parameters (from which the actual parameter object can still be selected) which makes iterating quicker when browsing multiple parameters.
ParametersMap is essentially just a performance increase when dealing with a lot of parameters or for when the parameters aren’t being modified.
