I’m using the DetailCurve.ByCurve to draw detail lines on sheets. It works on the first sheet, but continues to draw detail lines on the first sheet even though the active view has changed and been refreshed using a toggle and the Springs.Doc.ActiveView node:
The only way to purge the first view from the ByCurve node is to delete it and re-add it. Other nodes that rely on the ActiveView node are working properly. Any thoughts?
