For some reason I cannot get the element parameters of a detail group. The element parameters node will not even examine that specific element ID and bumps to the next on even though the element ID node shows the correct ID. See attached image.
It’s most likely showing you the id and parameters of the group type because the group instance doesn’t have any parameters of it’s own. This is easy to test. Select a few identical instances and you’ll notice that they all point to the same id - the id of their common type:
Thanks Dimitar!
