Hi All,
Just trying to add clearance lines via detail curve in active view, seems to pass through ok but does not translate to active view or any view to be found, any ideas what i could be missing?
Cheers Kai
Hi All,
Hi @Kai does it work if you pull on plane ?
Thanks @sovitek works with the clockwork DetailCurve.ByCurve node.
Tried the pull to plane and OTOB detailCurve.byCurve by curve but still no luck …
yeah ootb node have some issues…old story…it doesnt work on circle f.ex, so i always use clockworks
