Hello
i just wondered if there is a way to delete elements by ID from closed revit file
becasue i have damaged revit file because f of them
You can’t modify a Revit file without opening it. Best to submit the file to my colleagues in Autodesk Support to see if they can resolve the corruption.
Out of curiosity, how do you know which elements are causing the issue if you can’t get into the file?
while opening file give warning can’t be ignored and elements ID
Yep - send that one to the Revit support team.
Have you tried Auditing the files?
It opens the file for you because necessary to edit anything you like
https://www.birdtools-developers.com/dmu.html
