Hello everyone, how can I remove the file extension “.rfa” using Dynamo?
Hi alienau,
you could use the “String.Replace”-Node to replace “.rfa” with an empty string.
i hope this helps.
You could also just use a “false” with “FileSystem.FileName” and feed it into “withExtension”.
But this only works if you are looking to delete the file extension
thank you Max , it worked perfectly ![]()
