Is there any way to identify the deleted spaces? I mean, once we delete the space from the model, it will not go from schedule. Is there any way to filter the space which doesn’t have physical property.
Check to see if it has a Location. If it doesn’t, it isn’t placed. You can also double check to make sure it has no area, but location should do it.
Hi @SHIBUJOSE,
Filter the Space Category by the Area. If they have been deleted they should be empty.
@SHIBUJOSE @ben.dowling , this works 99.9% of the time, but it is possible to have placed spatial elements that don’t show an Area because they are inside a bounding element. I have ran into this before which is why I always use location AND area just to be certain, although the Location should be sufficient.
