Hi, started trying Dynamo to see what I could do with that. So I used a tonurbssurface from a surface, saved my file and closed dynamo. But now I can’t seem to select/delete the surface anymore from my Revit file, how can I delete it?
Close Revit and open it again.
When you want to run the Dynamo script again, right click on the node that generates the surface and turn off “Preview”.
Ok, thanks!
