Thanks in advance if anyone has some good ideas on this!
I have duplicated some views with detailing and would like to define a cropping area for them (manually in Revit). However, I have only found 2 yes/no parameters so far that define the cropping area
- activate cropping area
- make cropping area boundaries visible
However, I can’t find any setting options to define the cropping area coordinately in relation to the placed elements on the plan.
I can query the coordinates of my plan elements, but how can I define the plan section via Dynamo?
I also like to work with Python, but I am not yet clear about which parameter controls this. Is it possible to query the coordinates of the cropping area via Python?
By default this area covers the whole drawing window.
I tried to call the cropping area via all elements of category after setting a cropping area of a plan, but i only get empty lists for both options.
Update: Found some nodes to adapt cropboxes. I try to use these nodes, if i get a result i´ll give an update. (View.GetCropBox)
