How can I make a Shared parameter in Revit Family show me the date when the family was created or modified?
i can not answer directly, BUT there are two options:
1.) is create a library(folder) based on versions for any kind of family, so you can monitor changes based on a standard
2.) when you have a major project (f.e. 300 000m²), you can manage your families based on a content library (.rvt) where all families placed and maintained. Library is used as a “table” to get and set families.
KR
Andreas
Use Windows and os library in Python. Beyond that as Andreas said it’s up to your team to be diligent in version tracking and management.
Define “when the family was modified”.
If it means “the family type was modified in some way”, you could utilize the DocumentDifference api if you have daily backups available.
If it means the family document was modified, you’d need to track via an external library as noted above.
