I have a problem with setting the curve coordinate system to its correct orientation as some of the adaptive family being placed on the curve is flipped for this reason.
I have tried setting the coordinate system by using the CoordinateSystem.ByOriginVectors in Dynamo but I can’t seem to figure out why the curve still have the incorrect coordinate system. Refer to the screenshot for reference.
i would first create a 3D-line( out of points) and than get the placement point with the node “Curve.CoordinateSystemAtSegmentLength”. So you don’t need to calculate the Z-Axis of the coordinateSystem at point:
I can get the points from curve coordinate system at segment length as well but the approach doesn’t seem to solve the flipped coordinates on the curve.
I don’t know why this happens, but than you need to control the vector. Compare it with the z vector of the project system and if it not fit, reverse the vector.
