Hi Guys,
Need an urgent help.
I am working on the below script (attached below), it is performing OK for division of all horizontal grids but i am unable to do the same for the vertical grids.
Due to this the poly-surface extraction is not possible. Also for the vertical grids, a curve is getting generated instead of the needed division.
All files, including the Revit file is also attached.
Any help is highly appreciated.
Thanks a lot.
Curtain Wall.dyn (18.2 KB)
