3D polyline for revit.dwg (619.8 KB)
Drawing walls levels.dyn (15.3 KB)
Hello everyone, Previously I was using this script to draw walls along a path (module lines ) and it was working however, I am not able to select the 3D polyline in the DWG in which I have inserted it as a module line,
Anyone knows what’s the problem ?
or how can I draw walls along this DWG
Hi @ahmadkhalaf7892,
You can’t use spline to create walls. You must explode the DWG polyline in lines to be able to create the walls.The result will be an approximation. (Poycurve to curves)
Hi Alban
Thanks for the help , I have noticed that the select CAD Curve Node is not available , I have the genius loci package however I didn’t find the node , may I ask where can I find it ?
Great…Looks very nice with the new node
The new node will be available in the next Genius Loci package update.
In the meantime, you will have to use CAD layers and Element.Geometry or CAD.CurvesFromCADLayers nodes.
