Hello everyone,
can anybody help me find out why creating tag node didn’t work?
thanks,
Hi @Simo,
What is the family Fire Damper Round Standard ? A tag or a fire damper ?
Can you see the preview under the elements ?
Looks like you might not be feeding it a tag family.
@Alban_de_Chasteigner beat me to it! LOL
It needs to be an annotation element. You’re placing a tag, not an element.
Can you try to link the Flatten output" Fittings" of “MepFittingsBypointandcurve” node to the Input “Elements” of Create Annotation Tag ?
Actually you’re feeding Element type in create annotation Tag.
Can you tag manually your dampers ?
The message “There is no loaded tag type” says it isn’t possible to find a tag for the family.
You are right. I can’t tag fire dampers even if their tag type is loaded. I need to check that out and see
