I’m putting together a Python routine to draw some lines in the project environment.
The routine will draw some 3D lines mode lines in the project environment, not the family editor.
I’m struggling to work out which class is the one to use, the ones I try are cause exceptions as they are lines for family creation.
I believe you need to create a new unbound line, and then from that create NewModelCurve.
Is that correct, I’d appreciate an example of how to do this.
OK, thanks, I’ve got that already.
I guess the problem is I cannot create the SketchPlane for the model line in the model environment, I can do it easily in the family environment with:
plane = app.Create.NewPlane(normal, origin)
skplane = doc.FamilyCreate.NewSketchPlane(plane)
But cant find the model enviroment equivalent of doc.FamilyCreate.NewSketchPlane(plane), guess it would be doc.Create.NewSketchPlane(plane) - but that does not work.
This is my code:
newline = Autodesk.Revit.DB.Line.CreateBound(XYZ(0,0,0), XYZ(1000,1000,300))
origin = XYZ.Zero
normal = XYZ.BasisZ
skplane = doc.Create.NewSketchPlane(plane)
OUT = [levelid, newline, plane, plane, skplane]
and it generates an error with AttributeError: ‘Document’ object has no attribute ‘NewSketchPlane’
I feel like I’m missing something obvious…
SketchPlanes are created directly from the SketchPlane class:
http://www.revitapidocs.com/2017/51d4403a-b78d-7527-f3bc-463d8044d0d4.htm
something like this: sp1 = SketchPlane.Create(doc1, plane1)
OK, thanks that worked.
But I get transaction issues. The first time I run the code it works fine. If it run it again I get the error:
_Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. _
Starting a new transaction is not permitted. It could be because another transaction already started and has not been completed yet, or the document is in a state in which it cannot start a new transaction (e.g. during failure handling or a read-only mode, which could be either permanent or temporary).
I can only run it again if I restart Dynamo.
If I add a transaction into the code it state generates an exception stating that it cannot start a transaction as one is already in progress.
This is my code:
clr.AddReference('RevitAPI')
from math import atan2, radians, cos, sin, degrees
import time
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
app = uiapp.Application
adoc = doc.ActiveView
dataEnteringNode = IN
levelid = UnwrapElement(IN[0])
t = Transaction(doc, "Random Move")
t.Start()
origin = XYZ.Zero
normal = XYZ.BasisZ
skplane = SketchPlane.Create(doc, plane)
t.Commit
Should not all of this be handled by Dynamo’s transaction?
Thanks.
Maybe it’s because you are missing the parentheses after t.Commit
It’s probably better to use Dynamos transaction manager :
# Get the document
# "Start" the transaction
# Create a reference point (requires a transaction)
refPt = doc.FamilyCreate.NewReferencePoint(XYZ(0, 0, 0))
# "End" the transaction
