Hi all,
When using 1 Boolean toggle, everything goes well (just 4 tags, like supposed):
But when I use a list with true/false booleans, then it goes wrong (it makes 16 tags instead of 4).
Tried different levels, but still same.
Hi all,
It might be a list lacing issue. If you display the full graph with a preview, it will help in identifying the problem.
This is a snippet of Revit, the blue’s are rectangular ducts verticaly, those are now being handled in my script:
This is my Dynamo-file (hope it’s visible):
It’s the part on the right top corner
It’s a lacing issue. Set the lacing to longest on the create tag node and that should do it.
Yes!! That did it!
Now I feel stupid hahaha
