Hi guys,
I am creating a script to get rooms from a linked model and create spaces and then name them. I can get it to work however it appears to miss a few of the spaces. I think it is because they aer overlapping? can anyone help with what might be the issue? I am using DynamoMEP for space creation.
I have posted the error as well in case it helps with trouble shooting
Hello and welcome to the community
does your link and active model share coordinate system (origin) guess is worth to check
Have you performed the normal checks for Room Bounding elements and Separation Lines?
Out of all of the rooms in the project, how many spaces result in this warning? A low amount? A high amount? Do they share any common traits like locations, shared walls, etc.?
If it happens to be ‘all of them’, then you don’t have Room Bounding enabled in the Link.
