I’m trying to create shared parameters from a excel file.
I have a Huge list of IFC parameters that after some cleaning i would like to import into Revit shared parameters.
I tried the Orchid package and actually it works, but Its somehow limited. I can only assign one parameter type. That means If I have 10 parameters and half are “Yes / No” parameters and the other half are “Text parameters”, the Orchid node will only apply one Parameter (text for example).
I need to be capable to assign different types parameter to each parameter, so I tried the archilab node with seems that could do what I want, but It seems that I can’t make it work.
Anyone know what I am missing? Maybe the node its not intended to do what I want?
