Hi @erfajo - I looked briefly at the implementation:
I think that the node naming of the node is not aligned with the revit API/UI and instead was intended to be simpler to understand for new users - but I agree it seems to only add confusion since internally this node creates shared parameters using a shared parameter file.
I think in this case the group is used just as a way of avoiding collisions between parameters in the shared parameter file with the same name.
I defer to the community or Revit teams usually on Revit API functionality though. If you think we should get rid of this input, we can obsolete this node and change it in 3.0.
