Create floor with Floor.ByOutlineTypeAndLevel is not an Floor?
I want an floor but i get an foundation slab. Can someone give me an hint? It say floor but I got an Slab…
Can you confirm that the ‘Conc 150mm’ is actually listed as an option in your ‘Floor’ types within a conventional workflow?
The Floor Types node loads types from Structural Foundation Slabs as well for the user to pick.
No matter if it an arch floor, or struc floor or struc foundation slab, the object type for them is all Revit.Elements.Floor
I can confirm that. You can make an slab or an floor with the smae type.
I checked again you are right. An little change differents in the name. Thanks you for the help.
