Solved
The custom node lineloopmerge can be rewrtitten to function as an external pyhon module!
Which is interesting in my opinion because it can be embedded in a loop inside a python node (less nodes needed) and cleans up the amount of script yout working with. And you also dont have to import the packages anymore.
Underneath the code. I only added the function “def LineLoop(curves, margin):”.
The rest of the code is copied from the Springs package, node LineLoopMerge.
original = curves[:]
out1 = joinCurves(curves, margin)
return ReorderCurves(original,out1[0])
def OrderCurves(cl0,cl1):
def switch1(i, j, cl0 = cl0, cl1 = cl1):
cl0[i],cl0[j] = cl0[j],cl0[i]
cl1[i],cl1[j] = cl1[j],cl1[i]
_ln = len(cl1)
xr1 = xrange(_ln)
int_test = [[cl1[i].DoesIntersect(cl1[j])\
for j in xr1 if j != i] for i in xr1]
countT = map(sum, int_test)
if 0 not in countT:
if 1 in countT and countT[0] != 1 :
switch1(0, countT.index(1) )
for i in xrange(_ln - 1):
k = i + 1
if cl1[i].DoesIntersect(cl1[k]) : pass
else :
try:
int_test = [cl1[i].DoesIntersect(cl1[j])\
for j in xrange(k, _ln)]
switch1(k, k + int_test.index(True) )
except : pass
return cl0, cl1
def ClosedCase(cl0,cl1):
pts = [cl1[i-1].Intersect(cl1[i])[0] for i in xrange(len(cl1) )]
return PolyCurve.ByPoints(pts,True).Curves()
def OpenCase(cl0,cl1):
def FarPt(l1, p1):
pts = (l1.StartPoint,l1.EndPoint)
return max(pts, key = p1.DistanceTo)
pts = [cl1[i].Intersect(cl1[i+1])[0] for i in xrange(len(cl1) -1)]
pts.append(FarPt(cl0[-1],pts[-1]))
pts.insert(0,FarPt(cl0[0],pts[0]))
return PolyCurve.ByPoints(pts).Curves()
def joinCurves(cl0,th1):
len1 = len(cl0)
if len1 < 2 : return cl0, False
cl1 = [c.ExtendStart(th1).ExtendEnd(th1) for c in cl0]
cl0, cl1 = OrderCurves(cl0,cl1)
_fn = ClosedCase if cl1[0].DoesIntersect(cl1[-1]) and len1 > 2 else OpenCase
try : return _fn(cl0,cl1), True
except : return cl0, False
def ReorderCurves(orig, new):
reordered, new = [], list(new)
app1, pop1, PaP = reordered.append, new.pop, Curve.PointAtParameter
for i in xrange(len(orig) ):
p1 = PaP(orig[i],0.5)
p2 = [PaP(new[j],0.5) for j in xrange(len(new) )]
ind1 = p2.index(min(p2, key = p1.DistanceTo) )
app1(pop1(ind1) )
return reordered
