Create assembly / assembly views with planning tables
Translated by moderator. See below the line for original post.
Hello, who can help me create a Dynamo scrip to generate the views of a assembly with an already selected filter and planning tables. I attach what I could generate, I need to really take the tables of (structural frames and structural pillars) and to the views to put a filter of views that I have already generated.
Assembly view with tables 2222.dyn | Attachment (54.4 KB)
Original Post Below
Hola, quien me puede ayudar a crear un scrip de dynamo para generar las vistas de un montaje con un filtro ya seleccionado y tablas de planificacion. adjunto lo que pude generar, me falta que me tome realmente las tablas de (Armazon estructurales y Pilares estructurales) y a las vistas ponerles un filtro de vistas que ya tengo generado.
vista de montaje Con tablas 2222.dyn (54.4 KB)
Welcome to the forum @fedekiko66!
The language here is English, which is a requirement to make search work (annars skulle jag bara poat på svenska). Please translate future posts as I did in the edit of your post so that we can keep a working search. Keeping your original post below a demarcation line is also encouraged (might help should we get multiple languages supported someday).
