Create an insulation line that increases with slope
Hello. How can I ensure that the height of the insulation line in the image
increases proportionally to its length? Where should I start? Thanks
Hi @yaseminV2XL5 guess its more a family thing [guess its a line based family]
The first question has to be “How would you do this natively in Revit?” If you don’t have a valid way to do this in Revit then you don’t have a way to automate it in Dynamo. If there are certain requirements for doing this in Revit then what steps have you already solved and how much is left to be automated?
This looks like the use of the batt insultation graphic standard in a location where rigid insulation should be used. Is there even such a thing as increasing thickness batt insulation?
