Goodday,
I’m currently trying to define a code, based on database, for every model element in a project.
In the script below i select all elements within the current view. Then i filter the elements on the absence of a filled in code. Then i get a pop-up, Data-shapes, in which i can manually type the code needed.
I have to find the code manually in a huge database which is a long list with sublists in excel.
i was wondering if i could create an folder menu like windows as an input oppurtunity instead of a manual text box?
Thanks in advance,
