I want to create a dictionary where the key is associated to multiple values of different types. For instance, I want “option A” to be associated with the polycurve and the point shown in the graph below. Thanks in advance!
It worked, but I was hoping to find a quicker way. Thanks though!
When I call values, I get an error saying that “converting arrays would cause array rank reduction”. I wish someone thinks of a different solution!
Can you post an image of the result? I need to see how your list is structured in order to suggest a solution.
Before the dictionary
Convert all your values to a string
Concat all values with a special character in between
Store this concated string in the dictionary
After the dictionary is created
Extract the values (the concated string)
Use String.Split to get all the separated values back to what they were, leaving out the “special character”
Thank you Frank and Marcel for your help!
