I want to copy properties from architectural rooms to the corresponding spaces. Actually I already developed a script that works pretty fine on small models, however it is using Geometry.Intersect, which creates performance issues or even fails with many rooms…
I am wondering whether it’s possible to get the corresponding Room for a space using the Revit API? I diddn’t manage to find a package that solves this and I’m grateful for every hint - thanks!
Lejla
@Lejla_Secerbegovic, look at SpaceAtRoom from MEPover package.
hi @Vladimir,
thanks for the quick response, I did some testing (also with other packages) but unfortunately the performance issues still persist. I’ll post an update when we have a solution!
Cheers, Lejla
Hi @Lejla,
You can make 2 stages:
- Check Bounding Box intersections(works very fast).
- Check elements intersections using results from above.
And if Rooms and Spaces are on different levels, don’t check unnecessary intersections.
Using this approach, i reduced time from 45s to 13s.
If you’ll post RVT file, i could show you this.
P.S. I’ve looked into SpaceAtRoom node, it have to be fast, as it uses API.
