Hi guys,
I have a problem with Coordinate :
2771816.9810,1204166.6680,665.86
2771782.1890,1204178.2670,663.60
2771796.3540,1204194.7170,666.44
2771834.5790,1204196.8600,681.75
I start the script but I don’t see anything in revit
I can’t set it
I’m relatively new to the blog
Thanks in advance!
enne
You have to use internal coordinates. World coordinates - Project Base Point would give you the internal ones.
I set it like this:
in revit I don’t see it
I’m sorry I didn’t understand right away
Use GeniusLoci pack to get Project Locations and then use Geometry.Transform (CoordinateSystem) and get coordinates interno. You should have like small distances. The reason you don’t see anything is because Dynamo works in internal coordinate system. So 2721102.9810, 1204166.6680,0 is in Dynamo 0,0,0.
I have dynamo 2.5.0.7460 Revit 2021
I have to download the package
it also works on this ?
thanks
enne
