Hello, can someone confirm if this is an existing limitation with the node that is overlooked.
So I just need to extract the project basepoint of a project in Revit 2018.
The Coordinates.BasePoint node will stop working and at worst report different values when the project basepoint are in higher numbers in meters in Revit.
The basepoint values I’m working on are in range of 700,000.000 meters - N/S E/W. Can someone please try to replicate this process if it’s really a limitation. Thanks!
