Hi Guys is there a way to get rid of this error message other than putting Dynamo in extra large range. The reason being is that I am not sure if changing everyones dynamo settings to extra large for my entire team will break anyones scripts or make them take longer to run. Is there different sequence of the nodes that I can use to eliminate this error so that it runs without errors? please advise. thanks
In Dynamo you should work with local coordinates. If you enter the world coordinates in Dynamo it will be placed somewhere else. The project base point is in Dynamo 0,0,0.
I cant this is for extraction for trimble points. I need the world coordinate system data. I cant simply discard the data I am working with.
