Converting materials to solids
Hellow
How do i convert the materials from the pic below into solids so i can view them and perform other calculations.
I want to view on the materials not the elements they are in coz some elements are a sandwich of materials
Hi @smrema ,
The materials you retrieved, as seen in your screenshot are just the materials, they don’t have any solids attached to them. It seems like the node you used also outputs Areas and Volumes for each material, perhaps you could use those values for your calculations. However it’s hard to give good advice since the “calculations” you have to do aren’t specified.
I want to calculate the formwork for the materials, that why i need their solids so i can explode to get surfaces and do formwork calculations
Hi @smrema …could it work with parting ?
Hi @sovitek
Get CompoundStructureLayers and Wall CompoundStructureLayerslocation are in which package?
Genius Loci…:wink:
Thank you for your time! the other nodes work well but for the “elements.createparts”, It seems the elements are already in parts, so it doesn’t work. How do I get the solids of individual parts since “elements.solids” give of entire element.
Hi @smrema this one will only work on compound objects like floor walls roof etc…
