Hello!
I’m attempting to transform each point in a list, which contains multiple points (the exact number is unclear), into a new list representing vectors, with a fixed point as a reference.
The issue lies in the fact that Vector.ByPoint cannot process a list of points; it only accommodates a single point. Is there a workaround available, or must I resort to creating a .py script?
Nodes will automatically handle lists based on the list structure of the inputs. The issue you’re having is that your start point input is also in a list and therefore the node assumes you’re matching a list with a list. Reduce the input to just a single point and it will iterate correctly.
or adjust list lacing and list levels for the inputs.
Yeah but then you still have to deal with the extra list level later on. I’m lazy.
