# Converting Compound Walls to separate Walls
**URL:** <https://forum.dynamobim.com/t/converting-compound-walls-to-separate-walls/51164>\
**Category:** Revit\
**Tags:** revit, geometry, dynamo\
**Created:** [May 28, 2020, 12:58pm UTC](https://forum.dynamobim.com/t/converting-compound-walls-to-separate-walls/51164 "2020-05-28T12:58:36Z")\
**Showing post:** 2
**Author:** ![Alban\_de\_Chasteigner](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/alban_de_chasteigner/32/39650_2.png) [@Alban\_de\_Chasteigner](https://forum.dynamobim.com/u/Alban_de_Chasteigner)\
**Post date:** [May 28, 2020, 1:03pm UTC](https://forum.dynamobim.com/t/converting-compound-walls-to-separate-walls/51164/2 "2020-05-28T13:03:07Z")
Hi @filip.kabelis,
One workaround is to make parts of yours walls.
Otherwise, it is possible with the _Create Compound System FamilyType_, _Wall CompoundStructureLayersLocation_ and _Get CompoundStructureLayers_ nodes in _Genius Loci_ package.
Here is an example (it was the opposite case and it was probably more complicated)
> [@Merge multiple separate walls into a single wall with multiple layers](https://forum.dynamobim.com/t/merge-multiple-separate-walls-into-a-single-wall-with-multiple-layers/37680/3):
> Hi @NLA, Welcome to the Dynamo forum. It’s good practice to show one’s trials when asking for help. [[How to get help on the Dynamo forums](https://forum.dynamobim.com/t/how-to-get-help-on-the-dynamo-forums/4677) ]([http://How](http://How) to get help) Anyway here is an example :
_[View the full topic](https://forum.dynamobim.com/t/converting-compound-walls-to-separate-walls/51164)._
