Let’s say I have two different Custom Nodes that have the same input and output types, but they apply different processes to the data and so return different results. If I want to compare the results of one or the other Node, I currently rewire everything on the input side, while leaving both sets of outputs connected to the downstream graph.
Instead, Is there a way to make a “wire switching” node, that takes any data and then pipes it to a different output depending on some condition? It would make it easy to choose options, or indeed usefully apply different processes to different domains of input.
