I have been using Dynamo to generate multiple 3d views for the seats in an auditorium, but the front clipping plane is consistently farther away from the eye point than I would like, cutting off architectural elements. Is there a way to control the location of the front clipping plane in a 3d view? When I generate a 3d view without using Dynamo, I don’t have this problem, as the front clipping plane is much closer to the camera. Below is an image of the clipping plane generated manually in Revit, and then the one produced with the Dynamo node PerspectiveView.ByEyePointTargetAndElement.
Related topics
| Create Camera Perspective View at CCTV Locations | 0 | 940 | December 2, 2021 | |
| Set view range for ceiling plan | 10 | 1937 | October 27, 2020 | |
Create views for plan light analisys
1 | 752 | April 15, 2017 | |
| Using Dynamo to set work plane in 3D view | 6 | 3440 | December 21, 2024 | |
| What type of data can i get from view? | 2 | 512 | May 23, 2020 |
