Hi Dynamo users! Is there any nodes that having the parameters of connected pipes to the structure? There are few like Structure.PipeLowestBottomDepth, Structure.PipeUpperTopDepth. But I need to check if there is anything for Out Flow Pipe diameter and inner diameter, slope, thickness of pipe that I could export out to Excel.
I could not find this node. Is this node on the toolkit, on which version? Actually what I am trying to do is to get the outflow pipe parameters from the structure directly. As shown in the structure properties tab “Connections”. Any suggestions here?
I don’t think there is a node that gets the attached pipes from the Structure side. How I do it is I get the information from the pipes. Any pipes Start Structure is “out” an any pipes End Structure is “in”. You can then sort/ group/ and organize based on structure names.
Hope that helps.
@clarsenCNDZF see above. There is a node in my new package (Camber) that will do that.
Structure.ConnectedPipes
