I’m having an issue with a Dynamo script. I want to combine all the URLs into a single parameter, but every time I export this parameter, I can’t read it properly in Navisworks.
can you share some images of your parameter and script.
adding all the URL in a single parameter not recommended. However , in the image its looks fine. what is the issue?
The URL doesn’t work when I click on it.
when you have concat them they are not a valid url address any more, as Vijay say its not recommend then you need one url pr. parameter
