I have a list of Revit links in my project. My goal is to clash ducts in my master file, with walls in which ever Revit link I choose.
I have created a DataShapes workflow for the user to select from available links in the project, then I also have a manual input method using the “Links” node from Rhythm.
When I feed the link from Rhythm, my whole script works as expected and all relevant families get placed.
However, when I feed in the link from the “ReportRevitLinks” node from GeniusLoci (note it has EXACTLY the same Element ID), into the “LinkElement.OfCategory” node, the script does nothing, fails and no families get placed.
Can anyone tell me why this might be? I need to use the second option because I need the user to choose what link to clash with the ducts and this will change quite frequently.
Could this be a list level issue ?
In the first picture, you have a unique item (RevitLinkInstance).
In the second picture, you have a list with an item.
0 List
0 RevitLinkInstance
What happens if you add a block code with x[0] after the ListFilterByBoolMask to remove the list ?
It is working normally for me.
You should show your entire graph (at least the part before the LinkElement.OfCategory node) with the previews under the node enabled.
I’m then running a test to see if what the user selected, matches an existing “Link Name” from the GetDocuments node. Then from the code blocks on the right hand side(which are the linkinstances), I’m feeding that into the LinkElement.OfCategory node to run the clash on those links.
Does this seem correct?
