Compare two unequal lists
@mellouze, have tried that as well, with no luck.
@Keith_Wilkinson1, so you say it is not possible in the latest (2.0) dynamo, even with a core node?. It doesn’t make sense…
Is there any topic about versions compatibles? Versions of Revit, Dynamo and node packages? I am very confused.
Did you care about the lacing ? I see you are in shortest lacing. Try auto lacing. Please refer to my previous screenshot.
No, I’m saying I’ve not looked at 2.0. I’m working in 1.3.3 presently.
@mellouze post looks like it will do what you need though - one thing I’ve learnt over the years of using Dynamo is you need to look closely at how the nodes are set up - it’s easy to miss a lacing setting.
@mellouze @Keith_Wilkinson1, thank you so much guys! It worked out for me!
I have no excuses, but I usually is aware of the lacing and levels, and did also try different combinations, just not this one apparently.
Thanks again!
