Is there any way to find the common connector of two ducts? The purpose of this script is as follows. I need to split a lengthy duct into several pieces then i need to connect each other. I have another script to split the duct. i will use ConnectTo method to connect the ducts but i failed to filter the common connector. My code is as below:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Mechanical import *
import math
app = uiapp.Application
el1 = UnwrapElement(IN[1])
el2 = UnwrapElement(IN[2])
consA = el1.ConnectorManager.Connectors
consB = el2.ConnectorManager.Connectors
conListA = []
for cna in consA:
conListA.append(cna)
con1a = conListA[0]
con1b = conListA[1]
conList = []
for cn in consB:
conList.append(cn)
con2a = conList[0]
con2b = conList[1]
co = conListA + conList
originList = []
for i in co:
originList.append(i.Origin)
se = set(originList)
#TransactionManager.Instance.EnsureInTransaction(doc)
#out = c[0].ConnectTo(c[1])
#TransactionManager.Instance.TransactionTaskDone()
OUT = conListA,conList,se
